2n pto seal
erik
08-05-1999 07:32:33
The pto seal on my 1945 2N is leaking badly. I havent used the pto for years, so i didnt notice it. It has the original 1 1/8in spline. What are the steps to replace it? Can you do it without removing the shaft? Also, how much would the seal cost?
David (La)
08-05-1999 13:32:40
 Re: 2n pto seal in reply to erik, 08-05-1999 07:32:33
Dell mentioned a while back, if you park the tractor in a depression, a little nose down then you want need to drain the oil or leak any as I did when I opened it up.
llamas
08-05-1999 10:25:25
The seal is about $7.00.
Replacing it is easy, the PTO shaft assembly slides right out and replacing the seal takes 5 minutes, presuming the shaft is undamaged.
llater,
llamas
the archives are great...DE
08-05-1999 10:12:32
Check out this link to an archive search. This should get you going, then post the questions it doesn't answer for you.
Good luck.
