Order Ford 8N Parts Online
8N Air Cleaner Tube Hoses
Les (OH)
08-04-1999 16:09:23
Anyone know of a source for the hoses to connect the air cleaner to the tube & to the carb? Stevens Ag Parts shows the one for the carb end (1 1/2 id )
What about the other end ? Air cleaner to the tube, which is larger. I am guessing this is the way it is hooked up because of pictures in I&T FO4 manual.
Mike C in SF, Va
08-05-1999 16:36:12
 Re: 8N Air Cleaner Tube Hoses in reply to Les (OH), 08-04-1999 16:09:23
Ditto on Don's suggestion. I did mine last weekend with two sections cut from a radiator hose I got at Trak Auto for $2.59, plus two sets of clamps. My air cleaner pipe has a slightly bigger diameter than the carb intake pipe, and the connector tube has a slightly bigger piece of tube collar-welded on at the top. I used the same piece of hose for both ends, however, and just stretched the top end on. Works fine.
Les (OH)
08-05-1999 18:31:38
 Re: Re: 8N Air Cleaner Tube Hoses in reply to Mike C in SF, Va, 08-05-1999 16:36:12
Thanks for everyone's responses. Sure is nice to have a board to ask questions and get a"N" aNswer.
Hey busdriver
08-05-1999 13:13:11
See if there is a Industrial hose supply in your area, I was lucky enough to get a piece 1 5/8 " about a foot long, that had already been cut from a long roll, when going to the till to pay for it the employee stated it was about $8.00 a foot, when we got to the till he estimated lenght, saying that's not a foot, just take it. I said thank you and went home with it for nothing. Measured it when I got home, 14". The one I got was to made for all oil and gas products. Good luck.
Stan
Don
08-04-1999 20:41:47
I just go to auto parts store and get radiator hose and cut to length
Tyler(MD)
08-04-1999 16:35:59
Both pieces of hose are the same. I got mine through what use to be Ford/New Holland....now New Holland.
Tyler
