As many others have found , we have a worn down throttle lever (I guess that originally they even had a small ball bearing pressed into the underside at the end of the lever, is this correct?). and the serrated plate under the lever. Because of this the lever does not maintain it's position against the governor pressure.Is there any good remedy? I assume that there is no source (after market or otherwise) for new parts to fix this problem? Some say to put little bumps of hot electrode on the plate using a MIG welder. Others say try using a stronger spring at the bottom of the throttle rod. Others try 'shimming' under the plate. It seems with all the worn out 8N throttles out there, that someone would be making new after market parts such as the lever, plate, spring, etc.? I am hoping that with your experience and knowledge with the old Ford tractors, that you might come up with the best solution? It certainly is difficult to try and mow a rough field with a 'bush hog', when you have to keep one hand always on the throttle. Thanks for any and all help you can offer. Looking forward to hearing from you. Jim Musick Email: [email protected]
