Order Ford 9N Parts Online
9n AGE
Bob mc clurg
02-18-2000 20:46:09
I am having difficult determining the age of my 9N. The seriel number is difficult to read; the best I can determine is *9 124I543*. What does these numbers incidate? Also how difficult is it to rebuild the engine? The tractor has not run for a few years and I am thinking of completing rebuilding the tractor since I need to replace the raditor and a few other items like seals. Thanks!
Jim(UT)
02-19-2000 13:43:32
 Re: 9n AGE in reply to Bob mc clurg , 02-18-2000 20:46:09
There should be an "N" after the 9. What you are seeing as a 1 is probably part of the N. Capital I was used in place of numeral 1. Therefore I believe your serial number is really *9N241543* which makes it a 1946 2N. 2N serial numbers also started with a "9N...". Another place to look is the rear axle castings. There should be date codes on them. Jot them down and post them here or email them to me and I'll try to decipher them.
Bob Mc
02-19-2000 16:42:40
 Re: Re: 9n AGE in reply to Jim(UT), 02-19-2000 13:43:32
THANKS - JIM & AL After much effort I was finally able to determine the serial number as *9N24Ib43* which translate to "Star 9N241643 Star" which means the tractor is a FORD 2N manufacture in 1946. In addition, the hydraulic pump housing shows 9N 6051A which translate to May 1, 1946 and the right rear axle shows a date of 9-3-46. THANKS again. The rear axle to the body has a leak. How difficult is it to replace the seals and how difficult is it to rebuild the engine?
AL@NC
02-19-2000 06:00:29
This site will help you identify it.
