Some causes for backfiring ("back" = through carburettor): 1. Fuel mixture too lean 2. Spark timing too early 3. Ignition high tension cross-firing inside distributor cap and between spark plug wires (as mentioned in an earlier post) 3. Faulty ignition condenser (This also can cause flame/fire/popping out the exhaust.) 4. Faulty ignition coil (This also can cause flame/fire/popping out the exhaust.) 5. Condensed water inside distributor A shotgun approach: A. Distributor: Remove. (The ONLY way to work on it) Inspect cap for carbon tracks and non-sealing gaskets. Clean all electrical connections. Replace loose bushings. Assure that mechanical advance moves freely. New points/condenser. Set timing per the FO-4 manual. Use NEW gaskets and make SURE that they are IN PLACE to keep water out. TISCO (At your friendly local Ford dealer.) has all parts (You might have to search the catalog yourself.). Not having an I & T FO-4 manual is a handicap for any "N" owner. B. Spark plug wires: If they are stiff/hard, REPLACE THEM - it is overdue. Use a snake made of small diameter mechanic's wire (We used to call it bailing wire. Some call it Standard Ford Parts) C. Carburettor (There was an englisH forD, you know?): At least, clean all passages and jets and install new gaskets. If shafts are loose (making idle mixture and speed difficult to set), get the TISCO overhaul kit and replace shafts and bushings. Good luck Elvy
