Order Ford 8N Parts Online
8N PTO Shaft..1-1/8
Dale Whitehead
08-01-1999 06:34:55
Greetings,
I am in need of an original 1-1/8" PTO shaft with bearing assembly for my '47 8N. Anyone have one out there left over from their upgrade to the larger shaft?? Why go back to the smaller shaft you ask? Well, I have a belt Pulley, bolt on type, that will drive my Cider mill. Shaft size has to be 1-1/8". Larger upgrade will not fit. Thanks in advanc
Terry L. Houger
08-01-1999 09:36:32
 Re: 8N PTO Shaft..1-1/8 in reply to Dale Whitehead, 08-01-1999 06:34:55
I have a 1-1/8 I took off my 8N just a month ago to replace with new 1-3/8. The spline is quite worn though. This is a complete set: cast housing, bearing, seal collar and snap rings. It's a matter of removing 4 bolts, pull the old shaft out, poke the replacement assembly in and return the 4 mounting bolts.
Jot me a note it you're interested.
dave#1
08-01-1999 16:40:02
 Re: Re: 8N PTO Shaft..1-1/8 in reply to Terry L. Houger, 08-01-1999 09:36:32
Terry, If ya don't mind me ask'n, where did ya buy the new conversion shaft and how much $$ ? I'm due for a new shaft myself and want to upgrade to the 1-3/8" shaft.
thanks.
later,dave
EricG.NH
08-01-1999 06:56:14
Would a reducer work in your case? CT has them. Eric
