Another 12V conversion question
Kick
07-30-1999 07:49:56
I'm conveting '49 8N to 12v. Any suggestions on
encluding a fuse? Also terminal block drawing shows a place for resistor? Does'nt look like a resistor is there,and what's this ceramic and wire gadget between the key switch and terminal block. Looks like it could be a fuse or resistor. I know enough about wiring to be dangerous.
Robert
07-30-1999 22:49:50
 Re: another 12V conversion question in reply to Kick, 07-30-1999 07:49:56
I'm not sure how 8n conversion kits are designed. I made up my own wiring when I converted my tractor. Using a fuse is not a bad idea, they do serve a purpose, but I would suggest a fusible link. On my conversion, I used a 14 gauge fusible link(available at auto parts stores) connected to the BAT side of the starter solenoid to feed a 10 gauge wire going to the amp meter, which in turn goes to the terminal block and on to the BAT terminal of the 12v alternator. Even lower output alternators are capable of putting out 55 to 65 amps; depending on the quality of parts used to rebuild the alternator, the battery's state of charge and the RPM it turns. I know that tractor RPM's are lower than that of cars, but a good alternator can generate it's rated output even at moderate speed. I used a Delco 10 SI alternator, small as far as alternators go, but still rated at 63 amps.
I did, however, wire in a fuse holder with a 25 amp fuse at the terminal block to feed the rest of the system (ignition system and lights). Here I used 14 gauge wire.
I'm quite pleased with my 12v 8n, it's a worker not a show horse. Cranks like a dream on those cold winter mornings!!!!
Dell (WA)
07-30-1999 08:21:53
Kick..... ...This is a FAQ!!! The ceramic block is what is commonally called the "ballast resistor".
In a front mount 6 volt electrical system, it is designed to provide the correct opperating voltage to the coil. The coil was designed to operate on 4 volts. It was Fords answer to the fact that starting an engine really drags down the battery voltage (just while starting). In operation, the ballast resistor gets very hot and its resistance goes up reducing the voltage to the coil, but when cold its resistance is low and thus provides more battery voltage to the coil for eazier starting.
DO NOT remove the ballast resistor because you will burn out your coil because it is not designed to operate on 6 volts. And you will also burn out your distributor "points".
You will need an additional resistor to drop the 12 volts down to 6 volts and then the ballast resistor will drop the 6 volts down to 4 volts for the coil. Connect both resistors in "series" like flashlight batterys. OR you could change to 12 volt front mount coil and not muck around with ballast resistors at all.
Most 12 volt conversions do not include a "fuse" but you certainly can if you want to. Place about a 30 amp fuse in the battery charge line from the alternator.
Hope this helps..... ...Dell
Aaron
07-30-1999 21:30:46
 Re: Re: another 12V conversion question in reply to Dell (WA), 07-30-1999 08:21:53
Dell when i converted mine i added a ceramic resistor and had to pull start it every time. when i took the original resistor located on the firewall out of the loop it starts and runs fine.
does that sound right?
Dell (WA)
07-31-1999 23:12:03
 Re: Re: Re: another 12V conversion question in reply to Aaron, 07-30-1999 21:30:46
Aaron..... ..quite possible
Heres the skinnie..... ignition coils are designed to operate at a certian voltage. It doesn't matter how the operating voltage is derived.
If the coil was designed to operate on 9 volts, a transistor radio battery would do it (for a little while anyways). If it was designed to operate on 4 volts (which is what the 6 volt front mount coil is designed to do), eather 2 or 3 flashlight batteries would do it. Note: 2 flashlight batteries is 3 volts; 3 flashlight batteries is 4 1/2 volts. Eather way it would work. BUT 6 volts on a 4 volt coil will burn the coil out, but before it burned out it would be outputting about 50% more sparkies. A burned out coil is not a fair exchange for more sparkies in my opinion.
Now in your question as I understand it, what most likely happened is a "universal" 12 volt to 6 volt dropping resistor was pobably used. Universal means it probably will work in most cases. In your case, the universal dropping resistor worked more than what was needed to provide less than 6 volts to your "ballist resistor" which inturn provided less than the necessary 4 volts to really run the front mounted 6 volt coil. Therefore, when you took out the original ballist resistor you essentually provided about 4 volts thru the universal resistor to the front mount coil..... and vola'....everything works just like it should.
In electricity, some voltages are "absolutes" and some are approximates. That is to say, 12 volt battery really measures 12.6 volts and a 6 volt battery really measures 6.3 volts. And if a 6 volt system front mount coil really means it is designed for 4 volts BUT there is enuff tolarence such that any voltage about 3 volts will work BUT if the coil voltage is really 2.9 volts it just might not work at all.
Hope this explains why in your case, 2 resistors don't necessairally make a good working system..... ...Dell
Jim WI
08-03-1999 11:08:34
 Re: Re: Re: Re: another 12V conversion question in reply to Dell (WA), 07-31-1999 23:12:03
Just to add to the pot, my 2N uses two resistors wired in parallel as shown:
BAT -----| |----- COIL ---/\/\/\/---
With one resistor I only saw 3.0v at the coil (which wasn't enough to start and run reliably in the winter). Two resistors brought it up to about 4.7v (which is about the high end of the acceptable range). The 2N runs fine now.
'Course, now I'm having trouble with the carb (idle mixture screw doesn't affect it at all). The carb is in bad enough shape that I'm thinking of getting a new one.
Claus
07-30-1999 08:18:56
Most people do not put a fuse in the charge circuit, although it is not a bad idea. Go with at least 30 amps. This would save the diodes in the AC Generator (Alt) in case of low impedence in the charging circuit. The ceramic thigga majiggy is a ballast resistor for the coil. If you are using your original 6 volt coil, then you will need an additional dropping resistor in series with the ballast to drop the voltage down to six volts. It might be prudent at this time to change over to a 12 volt coil. Some of the 12 volt coils do not need any resistors in series with them. Check the documentation with the coil and or conversion instructions.
Happy Motoring
Claus
