Order Ford 8N Parts Online
8N front wheels
jd
07-28-1999 16:07:02
Are there any pick-up truck wheels that have the correct bolt pattern for the 8N? I want to keep my original fronts, but be able to swap to wider tires for mowing.I currently have 16" wheels on the front.
JOHN
07-29-1999 19:48:29
 Re: 8N front wheels in reply to jd, 07-28-1999 16:07:02
Interesting question:
What some previous owner had done with my 8N was to cut the center part out of the front rims, and then do the same with some old pickup truck rims; then take the center part of the 8N rims and weld them into the pickup rims. I guess he did it or the reasons you outlined. I finally got some new rims from one of the on-line dealers.
JOHN :>)
JK MN
07-29-1999 08:38:44
jd, Most all implement wheels are interchangeable to an ASAE standard, as long as the number of mounting holes are the same. ie there are; 4, 5, 6, and 8 hole wheels. (there are very few automotive wheels that will fit implements, even though they may have the correct number of mounting holes) The standard hub for your 8N has a; 6 bolt-6" circle with a 4.62" pilot or center guide hole. You will be able to go to your local farm implement supply store or tire store that carries implement wheels, and find wider rims that will fit the hub. Just be aware of the offset of the center vs the outer rim which will most probably have to be mounted on your hub in the "dish-out" position for tire clearance with the spindle. (Used wheels can be found in salvage yards, again beware of the center offset that you get a pair that are alike.)
chack with........Dell (WA)
07-29-1999 07:53:31
Miller Tires, an advertizer who supports this board. Rumor some implement "flotation rims/tires" fit 8N's but I don't rememeber the specifics..... ...Dell
