Order Ford 8N Parts Online
8N using post hole digger
Greg (TX)
07-28-1999 13:49:29
I am having trouble getting my post hole digger to come up high enough to clear the ground for traveling after digging a hole. Is there an adjustment for the high low travel on the hydraulics? I am trenching up my place whenever moving from one hole to the
Nolan
07-29-1999 05:35:54
 Re: 8N using post hole digger in reply to Greg (TX), 07-28-1999 13:49:29
You sure you've got the right auger on there? They make them in all sorts of different lengths. If yours is too long, you'd encounter the problems you're describing.
Greg(TX)
07-29-1999 06:35:13
 Re: Re: 8N using post hole digger in reply to Nolan, 07-29-1999 05:35:54
Exactly what I was thinking. Maybe I could talk to my local dealer and find out more about lengths to use et
Steve (IA)
07-28-1999 16:52:39
On my newer worksaver auger, there is a bracket with 3 positions for attaching the boom to the yoke. I had to trial and error each hole to get proper lift on my 8N. Don't know if all augers have this option, but it's some place to start.
Hope this helps.
