Order Ford 8N Parts Online
8N and Post hole digger
Greg (Tx)
07-28-1999 01:02:38
I am using a post hole digger on my 8N. I seem to be having trouble getting the boom pole high enough off of the ground to clear the auger from the hole. Is there a setting or adjustment for the maximum lift of the lift arms. Help..I am trenching my whole place up!
EricG.NH
07-28-1999 05:37:51
 Re: 8N and Post hole digger in reply to Greg (Tx), 07-28-1999 01:02:38
On my 8N and I think all of them there are two chisel marks that indicate the lift is at full height. They're used for adjusting the lift cover. There's one mark on each of the upper lift arms where they slide onto the lift arm shaft. The corresponding marks are on the lift cover itself somewhat on top in the same area. Use these to gage if your lift is reaching its full height. If not, then it should be able to be corrected by going through the lift cover adjustments.
Eric
P.S I assume your using position control and not draft control?
