8 N Gear Noise
Tom Halbrook
07-27-1999 07:41:36
I have a clunking noise somewhere in my powertake off / hydrolics mechanism. When I have a load on the the three point hitch there is a noise that sounds like a gear with a tooth off or a sloppy bearing on a shaft. If I dont't have any load on the lift, the noise stops. Also if I dis-engage the clutch the noise stops. Any Idea what this could be?
bg
07-27-1999 14:42:32
 Re: 8 N Gear Noise in reply to Tom Halbrook, 07-27-1999 07:41:36
Could be a bent PTO shaft, a broken tooth, a bad bearing, air in the hydraulic system, misadjusted hydraulic system, worn hydraulic system, etc. You need to do some serious isolation and diagnostics work. It's difficult to diagnose without hearing it and trying to discern a pattern, rhythm, or related noises and conditions.
