Jmbrown@hic.net
Governor HELP!
07-26-1999 12:08:55
how do you get the drive gear off the end of the governor shaft? I need to replace the shaft and i cant figure out how to get the drive gear off.
thanks
llamas
07-27-1999 03:41:21
 Re: jmbrown@hic.net in reply to Governor HELP!, 07-26-1999 12:08:55
I use a hydraulic press and bolster. I'd be leery of using a puller, as having the risk of chipping a tooth, but it does apparently work. Mark the shaft before you remove it to make sure you press the gear back to the same place.
I like to add a couple of small tack welds between shaft and pulley when I put it back - the press-fit will never be as good the second, or third, or fourth time, and you don't want the gear coming loose.
llater,
llamas
David (La)
07-26-1999 20:16:34
I got mine off with a sturdy two legged puller, it would be easier with a three legged puller. The puller shaft is 1\2" dia. I believe. It took about all it had to get the gear off.
bg
07-26-1999 12:16:58
The driven gear and shaft come out as an assembly. If you need to remove the gear it has to be pressed of with an arbor press or other such means.
