Order Ford 8N Parts Online
8N hydraulics suddenly acting wierd!!
Fletch_in_NC
07-20-1999 09:58:47
My great ole 8n has started only lifting 'bout half way in position control mode.With the selector set for full lift, if I move the position/draft lever forward 1/4 to 1/2 inch it will lift all the way up, then sloooowly start back down. If I play with the position/draft lever by moving it ever so slightly, I can make it stay all the way up. I hope someone out there has an idea that won't cost me an arm and a leg.
Thanks in advance,
Harry Fletcher
Troy L. Bell
06-24-2002 06:30:33
 Re: 8N hydraulics suddenly acting wierd!! in reply to Fletch_in_NC , 07-20-1999 09:58:47
I am sorry to tell you that it is the shuttle valve o-rings that are allowing the hydraulis fuild to bypass. My golden jubilee did the same thing. The easy and cheap fix is to pull the hydraulic assembly and clean it up. Then replace the o-rings. this usually fixes the problem if the asembly is not worn out.
EricG.NH
07-20-1999 10:07:08
The best idea, IMO, is to go through all the external and internal lift cover adjustments. And it's cheap too!
Eric
