8 N Problems
Fred
07-19-1999 07:43:26
Have the same problems as some other folks. When it gets hot it runs rough and dies. Have change coil, points, cond. plug wires, plugs. It is firing so fuel system next idea. Fuel is getting to carb. Book says there is filter in carb? Also vent in tank must be stopped up builds up pressure could this be the problem? Grateful for any ideas
Dell (WA)
07-19-1999 08:19:48
 Re: 8 N Problems in reply to Fred, 07-19-1999 07:43:26
Fred..... ..sounds like the ol' gunked up ignition switch contacts problem. Try a jumper wire with alligator clipies around the ignition switch next time it acts up. It usually takes about 1/2 hour for it to heat up enuff to drop the voltage to the coil so the sparkies don't.....spark too good.
I don't think your problem is a "carb" problem, one N-Board contributor claimed "90% of all carb problems are found in the ignition system" for what it is worth.
Yes, there is a filter in the brass elbow that feeds into the carb.
Yes, mud daubbers like to seal the "can't get to it" vent in the gas tank dome. You can run with the gas tank cap lightly closed so you don't get a vacuum if that is your problem. You can also get a "vented" gas cap but the environmentalists won't love you.
Hope this helps..... ...Dell
