52 8n w/ford 19
97 loader
jim herrick- Ma
02-15-2000 16:22:07
got the tractor runining again, thanks to the n-board, now the front hyd. pump just stopped spinning ??? shaft coming out of pump turns as does the ? coupling then it goes to a shaft and ? engine pulley turns with the engine but don't turn the pump?? what is the conection to the pulley?? going to take it apart tomorrow. and help would be greatly appreciated , did the 12 volt conversion, with the electronic ign. new starter coil. [needed the starter b/4 i decided to change over. thanks to all you guys and over a year of reading the board. spins like a top and starts cold or hot. GREAT
jim herrick- Maine
02-18-2000 20:24:58
 Re: 52 8n w/ford 19 - 97 loader in reply to jim herrick- Maine, 02-15-2000 16:22:07
re: guess either i'm the only one with this ford loader or the only one that has had a problem: a 9" x 3/4 in. shaft with 6 splines on one end and keyed on other, $19.83 and the hub that goes on the crankshaft pulley, $ 31.41 was the fix , it ate the spline off shaft and the hub. local "new holland dealer" was the great supplyer of parts , in stock items. just in time getting another snow storm up here in Maine.
