Order Ford 9N Parts Online
9N Hydraulics Danger
kwc
07-15-1999 11:55:28
Hi,
I am analyzing the behavior of my hydraulics and was hoping someone could comment on my findings.
I have a 9N with 1st, 2nd, 3rd and Reverse.
There is no draft mechanism on this one.
Problem 1: When I am sitting nuetral and I set throttle on high... I raise my implement by raising the hydraulics handle (located to the right of the seat) all the way up. My implement gets raised up all the way fine... I leave it there. Then I shut the tractor off. The implement slowly starts to fall. Is this normal? I would think that hydraulics would stay pumped until the lever is lowered. If this is not normal then how would I repair this ?
Problem 2: Using a Land pride Brush Hog for a mower (has 2 swinging blades)... My shaft has popped off several times because my hydraulics raised the implement too high. My PTO shaft is mangled and I have to replace because of this. The mower shaft flew off almost hitting me in the head. The slip clutch was useless and exaserbated the configuration. How can I prevent my hydraulics from floating like they are. My guess is that this model 9N operates this way dangerously and trhere is no way around it ? Unless someone otherwise characterizes the nature of this beast for me properly ?
Your help is very much appreciated.
[email protected]
uh-oh........Dell (WA)
07-15-1999 19:45:45
 Re: 9N Hydraulics Danger in reply to kwc, 07-15-1999 11:55:28
kc..... .this distresses me
problem 1) when your hydraulic system was brand new, it is claimed that it would hold a 2 bottom plow up overnight. As always, with use, ability deteriates over the years. How fast is "slowly starts to fall"? 10 minutes? 30 minutes? There are a lot of members who would be thrilled if the hydraulics would stay up 30 minutes. Mine will stay up for a couple of hours (but I honestly haven't timed it)
problem 2).....as the self-appointed safety preacher preaching the value and safety virtues of the "Over-Running Coupler", I am greatly concerned by your report. I am thankful that your head is still on.
Since I can not inspect the "damages" in person, I'm going to have to ask some questions.
When you say "PTO shaft is mangled", is this the mower's sliding 2 part PTO shaft or are you refering to your tractor's internal PTO shaft?
Did you "shorten" your mower's PTO shaft to accomodate the extended length of the ORC? If you didn't, I could visualize that your PTO shaft could "jam" when you raised your mower.
When you say "slip clutch", are you refering to the mower's driveline safety slip clutch? or do you really mean the ORC?
Was the tractor's "Over-Running Coupler" correctly installed?
Because 9Ns and 2Ns do not have a "position" control, their hydraulic height is free floating. The solution is what is commonally called "limit chains" which are under tension from the upper 3-point attach point under the tractor seat, down to the mower's lower lift pins. The chain lenth is adjusted for the desired mower height. When the hydraulics are "raised" the chain colapses and allows the mower to raise and returns to the preset chain limited height.
There is also available a stop device to clamp on your hydraulic lift lever's arch which you can use to prevent you from raising the mower too high.
Also highly recommended are "anti-sway bars" that triangulate from the mower's lower lift pins back to brackets mounted under the tractor's fenders. These keep the mower inline behind the tractor.
Brush-hogging is inherently dangerous due to the rotations energy envolved with those swinging arms an hitting a loose rock....ka-pow! but I have never heard of disasters like you have reported.
I and the rest of the N-Community would greatly appreciate it if you would report back concerning some of the questions I have raised.
Yours for safer tractoring, the safety preacher..... Dell
bob
07-15-1999 15:29:17
I believe the 9N has only draft contol, but not position control. Therefore, this is the reason for the constant movement. To solve this problem, you should install limiter chains which will allow the implement to be held by the adjustible chains at the low point rather than the weight being born by the hydraulics. As a result, the 3-pt will not rise inadvertantly and you won't have to constantly readjust the implement height. I bought mine at a tractor supply for about $18.
Dell!..Here is safety issue!!
07-15-1999 17:02:40
 Re: Re: 9N Hydraulics Danger in reply to bob, 07-15-1999 15:29:17
I have known for some time that some rotory mowers cannot be raised to the maximum height without binding on the PTO shaft. NEVER thought that it would do more than mess up the shaft! Large pieces of machinery flying around could be fatal!! Dell, you need to add this to your overrunning coupler warning.
WE DO NOT need to lose any members of "The Brotherhood" this way! Every 9N/2N newcomer should be told to RIGHT way to use a rotory mower.
I don't know since I use an 8N (or my 3000) to mow.
Larry 8N75381
