Order Ford 9N Parts Online
9n hydraulics idea (expert opinion needed)
David(mN)
02-14-2000 20:25:51
I'd love to have live hydraulics on my 9n (who wouldn't) for blowing snow(next year). would it be possible to mount a front end loader hydraulic pump on the engine crank and use this as a source of hydraulic pressure for the tractor. If so where and how would one "tap" into the hydraulic system and should the present pump be "disabled". Just thinking "outloud" I realize it would probably be easier to just find a 660 but I really like my 9n. Any takers out there. David
bg
02-16-2000 21:48:23
 Re: 9n hydraulics idea (expert opinion needed) in reply to David(mN), 02-14-2000 20:25:51
You should be able to find a front-end loader setup with the hydraulic reservoir built into the loader frame. Add the pump to the front(should be plenty of kits available for this) and use spool valves(should come w/ loader) to control the thing. No need to tap into internal hydraulics. You can use the internal pump by accessing the threaded port. This requires chaining down the lift arms and results in sluggish loader performance with gravity-down and trip-bucket loader. There should be beaucoups used N-series loaders out there with pump brackets and all. The biggest drawback is having to modify the grille to mount the pump. Maybe the guy in Florida will make you a red grille...
bg
02-16-2000 22:24:54
 Re: Re: 9n hydraulics idea (expert opinion needed) in reply to bg, 02-16-2000 21:48:23
Here's the Paulson loader for the N-series
tOTG
02-14-2000 23:38:38
This is very easy to do. Use a low volume (4 gpm @ 2000 rpm) front pump, tap lower side of hyd cavity for pump supply and upper area for return. You could remove your existing pump and replace it with a case-only (probably sell it to someone on this board and get their broken case) and block the inward side of the test port. Then activate the cylinder with a single-acting valve to the test port. You'd gain live hydraulic and positive height control. If your existing pump is good, you'd probably do the whole thing for a net cash wash.
John.CO
