After months of driving my tractor with no brakes, watching board postings, and researching the archives, I got the courage to fix them. Here is the procedure I followed. Things seem to be working, for now at least. Safety (check archives) Rear tires are generally filled with ballast, remove them using extreme care. On a level surface, I removed 5 and slightly loosened the remaining 3 lug nuts, then raised the rear of the tractor until its weight was on the floor jack. Then carefully "walk" the rear wheel from the hub, roll it to the front of the tractor and rest it over the front wheel. Now set the rear of the tractor firmly on the safety stand or adequate timber support. Proper tools �" socket set with 2" socket and cheater bar (30" to 36") Axle Puller that attaches to lug nuts in 3 places Floor Jack Good Safety Stand (3 6"x6"x24" wood timbers) Safety Glasses Procedure (check archives) Disassembly Once the rear wheel is off, back off the brakes with a screw driver through the adjustment hole using the star wheel adjuster until the drum spins freely. Remove the 4 brake drum safety screws and the drum should slide right off. You can now see the damage done by oil and determine which parts should be replaced. The axle hub can now be removed. Don�t use anything but the proper 3 point axle puller, I had to search a little but finally found one to rent for $8. After removing the wire retainer, loosen the main axle nut. This may require some effort, as the recommended tightening torque is between 400 and 500 foot pounds. I used a 2" socket wrench and a 30" cheater. This way my 160 pounds would give me the proper torque (2.5� x 160# = 400 ft lbs). Back the nut off but leave it on the axle so the end is flush with the end of the axle shaft, if the hub pops it won�t fly off. Remove the brakes, taking care with the springs. My brake shoes were almost new, but covered with oil and grease. I simply cleaned them (and all of the brake parts) with Brake Kleen, they look and seem to work pretty good. Remove the 4 studs and 2 bolts holding the axle seal brake support plate in place. Inspect the seal and mating surface on the hub. I found mine seal to be good and polished the hub mating surface. I don�t believe much oil was leaking past the seal. I am convinced oil was leaking though all of the other joints where there were no gaskets (see below). Remove the end shaft seal cork gasket on the axle shaft up against the bearing (it�s the diameter of the axle and about �" long p/n 4294). Finally remove 2 bolts holding the bearing retainer. Remove the shim pak, backing plate and gasket but leave the axle and bearing on the tractor. Assembly You will want to make sure all of the joints that are exposed to oil have gaskets and are sealed properly. I used Permatex silicone sealant on both sides of every gasket and shim. Clean all shims and clean or replace gaskets. Check that the shim pak is adjusted properly. I believe this adjustment insures the axle spins in the center thus is important to proper seal function. Please verify this procedure: Dry install the gasket, backing plate, gasket, shim(s), gasket, and bearing retainer. Remove shims until both axle shafts spin the same direction when the opposite wheel is rotated (transmission in gear). Add just enough shims so that the axle shafts spin in opposite directions when the wheel is rotated. Remove the above and clean, dry and re-pack the bearing with grease. Using a gasket sealer, carefully seal both sides of each gasket and of each shim and install the bearing retainer using the 2 rear bolts. The parts sequence from the axle housing is: Gasket(4130) -> Baking Plate -> Gasket(4130) -> Shim(s)(4229) -> Gasket(4130) -> Bearing Retainer -> Gasket(4130) �> Brake Support -> Gasket(4130) -> Seal/Retainer -> End Shaft Seal (4294) -> Hub -> Washer -> Nut -> Retainer Finish up by installing sealer and gaskets up to the hub seal. Attach the axle seal using the 2 support bolts and finally the 4 stud bolts and nuts. Install the brake shoes and slip a new cork end seal up against the bearing. I put Permatex sealer on the splines before I slipped the hub on the axle. Attach the hub and tighten the end nut. The specification is between 400 and 500 ft lbs. (Being cautious, I snugged the nut and did a final torque after the wheel was on.) Next install the brake drum and adjust the brakes. Carefully re-install the rear wheel. If you do this right and with a little thought and common sense, your axles should not leak (I hope) Good Luck
