Amp Gauge
Bishop / Louisi
02-14-2000 17:50:13
The amp meter on my 52 8N shows only 1 amp charge.
How many amps should the meter be showing. Can I use a -60 to 60+ Amp meter to check the output, and where can I connect it to test test the generator?
Claus
02-15-2000 04:12:43
 Re: Amp Gauge in reply to Bishop / Louisiana, 02-14-2000 17:50:13
The amount of current that charges the battery (On a functioning system) will depend on the state of charge of the battery. When the battery reaches near full charge, the charging current will go down to a trickle. This is (6 volt battery) about 7.5 volts. Now if the battery is in need of a charge, then 1 amp would be too low and you could have a problem with your charging system.
Happy Motoring
Claus
Bill(Tx)
02-15-2000 06:18:37
 Re: Re: Amp Gauge in reply to Claus, 02-15-2000 04:12:43
That would explain the instance when my amp gauge shows greater charge at initial startup of around 10-14 amps, then drop to 2-3 after running a little while. I don't know of the 12v (generator) system would be any different than the 6v with these results. And all this time I thought that the drop was a malfunction.
Claus
02-15-2000 08:57:03
 Re: Re: Re: Amp Gauge in reply to Bill(Tx), 02-15-2000 06:18:37
This is the indication of a good functioning system. When you first start the engine, you pull energy from the battery. This in turn lowers the battery voltage. When the system starts to charge, and replenishes the engergy lost, you will see a higher charge. As the voltage of the battery rises, the voltage regulator either vibrating mechanical type or electronic will cut the current back.
Happy Motoring
Claus
