2n center pin
joe m.
07-12-1999 10:46:58
my 2n has a sloppy front end and I am in the process of renewing all the bushings and bearings.
I am having much dificulty in in pulling the center pin. Have tried a slide hammer puller with no results. Soaked it with WD40 for a couple of days and tried again. Put heat to the housing
and still no go. Any suggestions ????
joe M.
07-19-1999 12:07:34
 Re: 2n center pin in reply to joe m., 07-12-1999 10:46:58
Thanks for the tips..
This is how I got it out.
I rented for free the largest slide hammer axle puller I could find and removed the axle lug adapter. I put the threaded end thru the crank handle opening and to the back of the king pin.
carefully installed a heavy washer and a nut on he puller shaft. I heated the area arround the front of the pin and with about twenty hard slams on the hammer it started to move and the rest was
a snap. I replaced all bushings in the front end
and it feels much different. Thanks again for your reply to my call for help !!
DE
07-12-1999 13:37:17
If you are talking about the king pin, someone on the board previously said to forget about PULLING it out, and I found from experience that he was right. What worked for me was pounding it out from the backside (easy for me because I already had the front end off the tractor).
I don't believe that mine would have ever come out from the front unless I could have somehow destroyed it in the process. It was so tight that it took me a couple of hours of pounding on an iron pipe of the diameter of the bushing with a 4-pound hammer and using lots of Liquid Wrench in the process. It was not one of my most fun times, but I finally got it out and replaced it. The old one was worn so bad that one side of the front was a sharp edge. The new one went in a lot easier than the old one coming out. Really tightened up the front end.
Removing the front end is not a terrible job and it may be your only option.
Good luck.
TimK
07-13-1999 13:40:12
 Re: Re: 2n center pin in reply to DE, 07-12-1999 13:37:17
I agree. The only way I got mine out was to pound it out after I had the front end off. What's happened is that the pin is worn so much there is a groove worn in it and that acts as a lip to prevent it from sliding out. Be sure you replace the bushing as well as the pin.
