Order Ford 9N Parts Online
9n Valves
Bill R
07-08-1999 04:35:57
Looking for advice regarding valves on my 9N.
Had to do a bunch of work with the hood off so I did a compression check. Starting with the cylinder nearest the transmission I had 100psi/35psi/45psi/90psi. They stay the same wet or dry. I pulled the head and found a broken intake valve on the 35psi but have not found any damage to the 45psi. What do i look for? I have removed the valves (Mushroom stem) from the two weak cylinders, should I do the rest? Do I need to replace the seats? Where do I find a cutter for the seats if so? Can I just lap the valves in if the seat is not to big? Do the springs go bad often? Any suggestions or hints will be appreciated.
bg
07-08-1999 10:28:21
 Re: 9n Valves in reply to Bill R, 07-08-1999 04:35:57
I'd replace all the valves and springs and take the block to a machine shop and have new hardened seats installed. I'd use the adjustable lifters and rotators.
ZANE
07-08-1999 05:15:56
Better check the guides for excessive wear and valve stem side movement. The split guide of the mushroom valve is more prone to excessive wear than the newer solid straight valve guide. You can replace all the valves and guides and lifters with the later adjustable valves that were in the 51 and 52 8Ns. To replace the mushroom valves you must grind the stem with a valve grinding machine to the proper tolerances to adjust them for valve lash clearance. This is something that takes a little practice.If you do the muchroom valves cool each valve in water before checking the valve lash each time you check after grinding the ends or it will be too long when hot and have too much clearance after it cools.
