3-point hydraulics stopped working on '53 Ford Jub
David
07-07-1999 05:41:27
Can anyone give me some ideas of where to start?
History of problem:
1. Hydraulics worked fine. 2. Attached a 3' augor WITHOUT an extender.
3. Dug 3' holes (let the augor go down all the way to the gear box before lifting out of hole)
4. This worked OK for about 40 holes, then on 1 hole I tried to lift the augor out and the hydraulics quit working (the arms suddenly lowered). The pump stopped, and it sounded like something "gave in" inside the hydraulic box.
I know I should have used an extender on the augor (which would have helped shove the dirt out of the hole, which in turn would have created less pull on the hydraulics).
What steps do I need to take in determining the problem? Any help at all would be appreciated.
AL@NC
07-07-1999 07:12:39
 Re: 3-point hydraulics stopped working on '53 Ford Jub in reply to David, 07-07-1999 05:41:27
Your pump is driven off of a gear that is driven by the ring gear on the fly wheel. Given the noise and complete failure of the hydraulics, this is the first thing I would check. Two bolts on the pump and you can lift it back for inspection. If this is not the problem then the manual has a good description on how to check the pressure. Good luck.
