3 pt lift problem
Todd Colglazier
07-07-1999 04:28:33
My 3 pt lift on an 8N only works for about an hour and then will not raise up at all. I replaced the central valve, cleaned the gunk out of the pump, changed the oil and knocked the lever mount back but it didn't help much. Any suggestions? I have heard that the seats get worn out on these.
David Martin
07-10-1999 16:37:11
 Re: 3 pt lift problem in reply to Todd Colglazier, 07-07-1999 04:28:33
May want to look for a crack in the pump itself. As the housing heats up and the oil viscosity breaks down due to heat, the lift becomes useless. The pump usually cracks on the inside, meaning you must 1st remove the pump and remove the guts. I have mine on the workbench right now. There is really not much to it, just mess.
