Order Ford 8N Parts Online
8N Stalls
John Sullivan
07-05-1999 13:31:15
The 8N runs for about an hour, then starts to sputter and stalls, it won't restart until it cools down. New distributor and carb so I don't think it is bad parts. I smell fuel. Could it be hot fuel handling? I have only had this tractor about 2 weeks.
Steve (IA)
07-05-1999 14:35:16
 Re: 8N Stalls in reply to John Sullivan, 07-05-1999 13:31:15
You say new distributor. Does that include new coil? A bad coil will work until hot then sputter quit and then when cool will run ok.
Good luck.
bg
07-05-1999 21:21:36
 Re: Re: 8N Stalls in reply to Steve (IA), 07-05-1999 14:35:16
The reason you smell gas is because it is not being burned. An updraft carburetor tends to flow back toward the outside, unlike an downdraft where the gas goes into the manifold. The reason the gas is not burning is because you have no spark, either due to a bad coil, condensor,or other ignition component, timing, but most likely the coil. The coil has to transform 6 to over 20,000 at the plug. When it gets hot, the resistance gets too high for the rapid discharge and re-energizing required.
