Order Ford 9N Parts Online
9N Fan belt replacement
John Fox
02-13-2000 09:05:48
I have a Ford 9N with hydralic loader. The shaft
from the hydralic pump is making it tough to replace the fan belt.
What Am I missing?
Ed
02-14-2000 10:56:15
 Re: 9N Fan belt replacement in reply to John Fox, 02-13-2000 09:05:48
I just went through the same thing. I swore the shaft was welded to the front plate. It looks welded because of the way it was beveled and there were no gaps or seams to give it away. Just before I removed the thing with a sawzall I gave it a twist clockwise (because it is a backwards thread) with a pipe wrench (mainly because I found it before I found the sawzall) The shaft loosened and turned out. Even then it is tough to remove the plate but when it is out the belt change is a snap. If you have to remove it by other means the replacement parts for the threaded shaft are available and it would make it easier to service in the future. The only alternative is to remove the whole front axle assembly. If you have any more problems repost and will try to help.
Ed
Wick,De.
02-13-2000 20:46:23
What kindof loader do you have?
Ringy
02-13-2000 10:26:06
The shaft that turns your pump should come right out when you un-couple it from the pump. It is a splined shaft. Should be no problem.
John Fox
02-13-2000 14:27:42
 Re: Re: 9N Fan belt replacement in reply to Ringy, 02-13-2000 10:26:06
Thanks for the quick reply.
The shaft from the hydralic pump has a plate with
four pins that fit into the pulley on the front of the engine.
I can't get the belt around the pins, and there doesn't seem to be any threads or set screws holding the plate (with pins) on to the shaft.
tOTG
02-13-2000 19:26:15
 Re: Re: Re: 9N Fan belt replacement in reply to John Fox, 02-13-2000 14:27:42
With enough force the shaft will unscrew from the 4 pin hub. This is a backward thread, so you need to turn clockwise to loosen.
John.CO
Ringy
02-13-2000 15:17:18
Sorry, mine is not like that. It seems like some fellas we talking about this same thing about a week or two ago on this board. I don't have any experience with the type your talking about. Sorry I couldn't help.
