Order Ford 8N Parts Online
8N rear axle bearings replace
David H. from L
07-04-1999 07:25:16
I have purchased my first 8N, 331776 and it is pretty rough. I have started in on the axles and bearings. One hub was worn and had tons of slack so it goes. In replacing the seals and bearings on the good axle and hub, I found when bolting the bearing retainer back to the axle bugle that there was nearly a 1\4" of in out slack between the axle and bearing with the bearing retainer and race??? I am confused, I thought that the clearance would be around .002-.006" with the opposing axle? Does both axles need to be in for this slack to go away or what? I compared both axles and they are identical other than one has a 1 1\8" OD thread and the other has 1 1\4" OD thread for nut. Help please.
David H. from La.
07-04-1999 10:53:01
 Re: 8N rear axle bearings replace in reply to David H. from La., 07-04-1999 07:25:16
Disregard the first message. I put in the opposing axle and the slop went away. Both axles do indeed need to be in to set the clearance. I am going to throw away one bad axle and while waiting on the arrival of replacement I thought I could adjust the other and save some time.
