Order Ford 9N Parts Online
1940 9n left brake
Wally (MO)
02-13-2000 06:53:32
I am looking for a way to make the left brake more servicable. One suggestion I have had is to weld a rod sticking up to the operating shaft and using this rod as a hand brake. Any suggestions out there Thanks Wally Lees's Summit MO.
Eli, TX
02-13-2000 16:59:54
 Re: 1940 9n left brake in reply to Wally (MO), 02-13-2000 06:53:32
There is a pawl on the clutch shaft that will engage the brake shaft. If this pawl is properly adjusted, you can engage the left brake by depressing the clutch pedal. That's the way it is on a 2N and I presume also on the 9. I seldom ever use the left brake pedal.
