Order Ford 9N Parts Online
9N running hot
Neil (OH)
07-03-1999 01:10:51
My brother in law uses a 9N to mow a large lot
with a finish mower, and has done so without problems for a few years. He tells me that the
9N is now overheating in a matter of about ten
minutes of mowing.
Here's what I know about it:
There is no thermostat.
The hoses, belt tension, and coolant are OK.
He replaced the water pump last year with a new
after market type. Someone suggested that the
impellers on these pumps can work loose. Any
idea as to the likelyhood of this?
Since the problem was sudden in onset, I think
something has failed. Suggestions will be
appreciated.
Neil
bg
07-03-1999 07:31:31
 Re: 9N running hot in reply to Neil (OH), 07-03-1999 01:10:51
He needs to have the radiator flow-checked by a radiator shop. Also check the timing and flush out the block(do it with the engine cold while the radiator is off.) The lower half of the radiator is probably clogged up w/ rust and gunk.
