Order Ford 9N Parts Online
9N carb low speed adjustment
Gary Ford
06-28-1999 07:25:06
I have reworked the carb and cleaned and blew air through every hole I could find. Tractor starts and runs, but low speed adjustment on carb does nothing....all in or all out....What's the deal?
daz
06-28-1999 16:33:30
 Re: 9N carb low speed adjustment in reply to Gary Ford, 06-28-1999 07:25:06
Gary, there is an idle jet (#250596) that may be messed up even if it's clean. It may be out of shape due to a screwdriver or the needle turned in too tight. That may be your problem if you didn't already replace it. Good luck. daz (Oh)
Dell (WA)
06-28-1999 08:14:43
Gary..... .I'd set the "low speed" to 1 turn like the book sez and look for bound up linkages. If nothing is "obvious" then you'll probably have to do another carb R&R, but then you're up on the learning curve (grin).
Good Luck.....Dell
ZANE
06-28-1999 18:28:41
 Re: Re: 9N carb low speed adjustment in reply to Dell (WA), 06-28-1999 08:14:43
In order for the Marvel carburator to idle the gasket that goes in between the bowl and the throat of the carb. Where the two surfaces mate must seal completely this surface is sometimes not finished very good on the marvel and their may be some uneveness around the edge of the two mating surfaces especially if the carb has had a few too many brogan adjusts.(pecked on with various and sundried things to stop it leaking etc. These mating surfaced can be leveled by Lapping them on a good sheet of about 100 grit wet or dry sand paper laid on a flat solid surface.Use a figure 8 motion till all the bumps are gone. You can also do the same thing with a large flat file but it won't be as flat as lapping.The object is to prevent any air leak where the idle Passageway connects between the two surfaces. If you get this sealed properly it will idle.The passageways also must be free of any foreign materials. The best tool besides compressed air that I have found to clean out the various size passages and orfices is a welders tip cleaner. Added on Date: 15:49:36 1/27/99
