Add-on hydraulic control valve
Micheal
06-28-1999 06:29:05
Hi, I wonder if some of you guys who have had more experience with hydraulics than myself could help. I have a '48 8N with front-pump and control valve for my loader, but it only has one-way control. The valve has the port on it for what appears to be the other way also. I put a hose on there and was hoping to be able to use a remote cylinder from this valve. When I got it hooked up lastnight, the remote cylinder would not work. It acted like the ram wanted to move but it could not. Do any of you knowledgeable folks know if a one-way valve will work as a two-way valve? Do I have to do something different with the valve other than add the second port hose to it? Any help will be greatly appreciated. thanks for the great wealth of knowledge on this board.
Thank you
micheal
Dell (WA)
06-28-1999 08:04:01
 Re: add-on hydraulic control valve in reply to Micheal, 06-28-1999 06:29:05
Micheal..... .most of those old N-tractor hydraulic systems are 1-way, power up, gravity down.
There is no reason why, after you take a course in hydraulics, you could not convert to other types of systems but it would take too long to teach on the N-Board.
Just my opinion, "not a hydraulics expert"..... .Dell
JK MN
06-28-1999 06:53:47
Micheal, Is there a name of the manufacturer on the valve, or numbers stamped in the casting? If so, post those. Some one-way valves can be converted to two-way by the addition of an internal plug that relieves the pressure of the external plugged port. It cannot be converted if the valve spool is designed for the one-way.
micheal
06-28-1999 15:22:04
 Re: Re: add-on hydraulic control valve in reply to JK MN, 06-28-1999 06:53:47
Thanks, I will try and scrub the crud off it tonight and see if I can come up with some more info.
Thank you, very much
micheal
Micheal
06-29-1999 05:38:12
 Re: Re: Re: add-on hydraulic control valve in reply to micheal, 06-28-1999 15:22:04
Hi, Here is what I found on the valve body.
GRESEN
MINNEAPOLIS in an oval pattern on the lever-end of the valve.
then 077 4 on the lever-side of the first working port.
550 between the two working ports.
Hope this helps and someone can give me info on if this is a convertable valve from one-way to two-way operation.
thank you for your time.
micheal
JK MN
06-29-1999 10:31:10
 Re: Re: Re: Re: add-on hydraulic control valve in reply to Micheal, 06-29-1999 05:38:12
Micheal, I cannot find any kit or a way of changing your valve from single to double acting. The control spool is not machined the same, and spools are not normal replaceble items. (Changing from a double to a single is easily done by plumbing the not needed work port into the return line with a tee). Most Gresen valves are not convertable. You will have to istall a double acting valve to work your two way cylinder. You may want to consider a two spool valve with the first spool a single acting position to operate the loader, and the second spool, a double acting to operate the two way cylinder, and that way you can plumb the work ports to a hydraulic coupler set.
Micheal
06-29-1999 15:46:22
 Re: Re: Re: Re: Re: add-on hydraulic control valve in reply to JK MN, 06-29-1999 10:31:10
Thank you very much JK. I very much appreciate the info. I will purchase another valve. thank you.
micheal
