Appreciate some help
Scott
06-27-1999 18:08:34
This may sound naive, but i just do not know. How can I tell the condition of an 8n. Just what makes it "good condition," "fair condition" and so on. Also, what would I expect to pay for an 8n in good condition. I have been following the papers here and seems that they sell anywhere from 1500 to 3500.
Robert
06-28-1999 20:53:34
 Re: appreciate some help in reply to Scott, 06-27-1999 18:08:34
Let me add one more thing from my experience. Over many years, moisture accumulated in the transmission of my 8n even though it was parked under a shelter. Condensation perhaps? or maybe it was exposed to more rain(which got by the shifter boot)before I got it. The gear oil eventually transformed into a milky brown goo. I ended up rebuilding the lift and pump. What a mess. Check the oil on the dipstick and pull the transmission filler plug and have a look in there with a flashlight. See what the gear oil looks like.
mikeb
06-28-1999 05:59:19
well, after owning an early serial number 48 8N and replacing most everything on it I can offer the following. Look for a side mount distributor, they are much less troublesome. Take off the valve inspection plate and see it it has the valve rotators and adjustable tappets. Check the steering geer for excessive play and wear. Put something heavy on the lift and see how long it stays up without leakdown, run the engine for 20 minutes and look in the radiator for signs of oil. Check the brakes and make sure they are dry and work. Look over the tires, sheet metal, tie rod ends, look for missing or badly repaired parts, welds, etc. I gave 2200 for mine and have spent about a grand getting it to where i want it. But I can say one thing, they are easy to repair and understand, they are hard working reliable little tractors. The only way i would part with mine is to trade it up for a jubilee with live lift and overhead valves. They were made to last and last, not like today's throw away society. I think that a good later model 8N with an implement or two could easily be worth 3000 bucks compared with a worn out compact diesel starting at 5K, theres no comparison. and besides, you get to own a piece of history.
EricG.NH
06-28-1999 06:35:11
 Re: Re: appreciate some help in reply to mikeb, 06-28-1999 05:59:19
Well said! I'd like to add a couple things also. Check the engine's compression. This will tell you a lot. Roughly, any reading less than 50-60 is questionable, 90-100 normal, 70-80 average, with all cylinders within 10psi of one another. I like to give the wheels a good shake looking for loosness, and stand back a ways a site down the length of the tractor. I've spotted many a bent spindle doing this. Run it for as long as you can. Minimum 20min. Check the guages, oil pressure s/b about 20-30 cold and drop a little 15-25 when hot. Ammeter should read negative amps when cranking, positive when running, 5 amps or so. Use your nose! Stick your fingers in the exhaust and smell'em :o). Do they smell like gas or oil? Open the radiator cap and smell that too.
Everyone's idea of poor, fair, average, good, very good and excellent vary. For me "good" means: most everything works, needs minor work on the other things. Tin mostly straight, needs paint. Tractor is very usable. These go for $2K-$2500 in my area, New England. Eric
