Order Ford 8N Parts Online
8N compression test
Mike In WI
02-11-2000 11:53:00
Ran a compression test and found #1 40 PSI #2 80 PSI #3 90 PSI #4 40 Psi add oil to 1 and 4 rasied them both 20 Psi .Most common problems? Thank you
llamas
02-11-2000 12:17:05
 Re: 8N compression test in reply to Mike In WI, 02-11-2000 11:53:00
Well, those are pretty clear-cut results. I would say, unless you have other evidence to the contrary, that you have completely shot rings in number 1 and 4, and you're in good shape in numbers 2 and 3.
I'm afarid you're looking at a tear-down. At the very least, a rebore and new rings. At worst, new sleeves, rings and maybe pistons. Only a micrometer will tell you for sure.
llater,
llamas
