Order Ford 9N Parts Online
9n will not run.
Tom
06-19-1999 19:49:59
I have recently come into the posession of my first N. I have rebuilt the carb, added new coil with condensor and points, set timming. Yseterday I had spark at the plugs today I don't. I have determined there is power to the coil and every other electrical component of the tractor. I am at a loss as to why it won't fire.
I am be comeing an expert at removeing and cecking the distributor.
Any help or suggestions would be appriciated,thanks for the help. I've already learned a vast amount by reading this forum.
ZANE
06-20-1999 06:06:21
 Re: 9n will not run. in reply to Tom, 06-19-1999 19:49:59
Make sure that the resistor is in the circuit between the ignition switch to the coil.If it is not and full voltage is going to the coil it is easy to overheat the points and with the new points that are fabricated from plastic this overheating will quickly distort the shape of the points, usually causing them to close up and sometimes it will not be possible to readjust them.It can also overheat the coil and damage it or ruin it.
If you can find them I would reccommend that you only use the original equipment type points that were and are fabricated from Bakelite material which is a fabric impregnated material that is impervious to heat.
Jim (CA)
06-19-1999 21:06:05
2 bolts hold the distributer in. I take mine out of the tractor to install points. You can set them right that way. Make sure your condensor is not at an angle or your coil won't seat properly. Pull the distributor cap off before you remove it to see the direction the rotor is pointing. istall the same way.
Dell (WA)
06-19-1999 20:32:31
Tom..... .My best guess is.....point gap, eather full open or most likely full closed due to the spring on the points arm. Sometimes the points setting screw is a little touchy about getting tight enuff and will slide close with a little engine running time.
Remember, its when the points open that creates the sparkies, but if the points are not closed long enuff (wide gap) sparkies won't be hot enuff to light your fire.
Check to make certain that you didn't strip any of the screw threads or the plate nut threads. Naturally, this only happens on weekends....Two options, drill and tap for the next size screw or wait until Ford/New Holland opens up and get a new points mounting plate.
Hope this helps..... .Dell
bg
06-19-1999 20:27:21
Make sure the contact spring on the bottom of the coil is making contact. Replace condensor(no easy way to check it) and check output at coil with a VOM. The easiest(not cheapest) way to check the coil is to replace it. Make sure the points haven't closed up.
