42 MODEL 9N
SETTING TIME FOR DISTRIBUTOR
JESSE IN S.C.
06-18-1999 19:13:06
I'M GETTING READY TO PLACE MY DISTRIBUTOR BACK ON A FULLY REBUILT 9N ENGINE AND AM UNSURE OF THE STEPS TO TAKE TO MAKE SURE I PUT THE DISTRIBUTOR ON AT THE RIGHT POINT. I CAN REMOVE THE VALVE INSPECTION COVER TO SEE WHEN BOTH VALVES OF THE #1 PISTON ARE CLOSED AND ON COMPRESSION STROKE. IS THIS WHAT I'M LOOKING FOR????? ??
dave#1
06-18-1999 19:27:28
 Re: 42 MODEL 9N - SETTING TIME FOR DISTRIBUTOR in reply to JESSE IN S.C., 06-18-1999 19:13:06
The "Key" on the dist. and the "Slot" on the cam gear are offset just alittle!!, this way you can only put the dist on one way.
later,dave
JESSE IN SC
06-18-1999 19:34:36
 Re: Re: 42 MODEL 9N - SETTING TIME FOR DISTRIBUTOR in reply to dave#1, 06-18-1999 19:27:28
DAVE, THANKS FOR YOUR RESPONSE. SO AS LONG AS MY TIMING IS SET CORRECTLY, THERE IS NO WAY I SHOULD BE ABLE TO MESS THIS UP?
dave#1
06-18-1999 19:41:19
 Re: Re: Re: 42 MODEL 9N - SETTING TIME FOR DISTRIBUTOR in reply to JESSE IN SC, 06-18-1999 19:34:36
You got it !! I'm sure your looking forward to hearing that baby purr !(-:
later,dave
JESSE IN SC
06-18-1999 19:45:52
 Re: Re: Re: Re: 42 MODEL 9N - SETTING TIME FOR DISTRIBUTOR in reply to dave#1, 06-18-1999 19:41:19
HEY DAVE, PURR I HOPE IT DOES. IT'S NOT EVERY DAY I WORK ON ENGINES AND I'M READY TO GET TO PLAY ON THE THING FOR A LONG TIME BEFORE I HAVE TO WORK ON IT AGAIN..... ..
