Any ideas for parts? Post Hole Digger made with Ford Rear End
Greg in Orovill
06-17-1999 18:58:21
Posted this on the implements page, but with no response.
I bought a used 3 pt post hole digger with a 9" auger for $150 for my 2N. It has removable blades and tip. The entire end piece is about 6" long and has a bolt that holds it in place. It does have a number on it (1220A I think). It works okay, but only in soft dirt. Anybody have any info so I can get tip parts. It uses a Ford Rear End with one end sealed. I thought at first it was a homemade job, but looks too good unless whoever built it was an engineer. Anyway, anyone have an idea of who makes it or the auger tip? As a last minute thought, did Ford build post hole diggers with their rear ends from cars? Somebody said it's a Pinto rear end. Appreciate any help. Thanks.
P.S. What does anyone think about adding weight for downforce? I am extremely safety minded.
Ed Gooding (VA)
06-19-1999 04:55:19
 Re: Any ideas for parts? Post Hole Digger made with Ford Rear End in reply to Greg in Oroville, CA, 06-17-1999 18:58:21
You can buy replacement cutters for the auger bit from your New Holland dealer. With good cutters, you won't have to put that much downforce, unless you are drilling in some serious hardpan. John Bower of this forum once suggested welding a "stub" onto the top of the auger gear housing and, when needed, using a 4-6' length of pipe, inserted over the stub, to apply down force on the auger.
Hope this helps..... ...Ed
'52 8N475798
raytasch
06-18-1999 06:40:05
Business associate has a post hole digger made from a Ford rear end. It is a very nice unit; little crude but very functional. Don't think you could tear it up with the power any N could produce. We put down several hundred 6" holes a while back rebuilding some of my fence. If you had some concentrated weight to add I would think it might be helpful although we had no problem getting it to "cut" in my sand-hardpan. The tip will possibly require a few "smithing" skills as most of us eventually acquire. Most areas have an "old boy" or two who can fix or make any repairs or modifications you might need. A good welder using a hard rod can put a good cutting edge on any tip. I've seen augers and tips advertised for sale--don't remember where. Good luck,
ray
Nolan
06-18-1999 03:36:09
There's a set of plans for making a post hole digger available through the n-newsletter. Haven't sent this weeks order for plans and articles in yet, so I haven't actually seen it. But I wonder if this might be the critter.
As far as tips and such go, unless the auger itself is some bizare and incompable home made job, I've seen auger bits and such right there on the shelf at CT and TSC both.
