Jubilee Help (please:)
LED
06-16-1999 12:47:32
I have one Jubilee and it runs after setting for appx 5-10 minutes then dies, then after awhile it runs for another 5-10 minutes. I have had the carb rebuilt but still the same thing:(....Any Ideals? TIA
David
06-16-1999 15:49:57
 Re: Jubilee Help (please:) in reply to LED, 06-16-1999 12:47:32
You need to check the coil,after you let it run and it quits . Check the fireing of the coil. Sometimes when a coil gets hot, it breaks down, and then when it cools off it will work again. Just a suggestion that would be my first thing to check on it.
ROF
06-16-1999 18:41:57
 Re: Re: Jubilee Help (please:) in reply to David, 06-16-1999 15:49:57
If you are using a inline fuel filter, try connecting diretly from the sediment bowl to the carburator. According to Ford, the downdraft carburator is not designed for an inline fuel filter. If elemilating fuel filter solves your problem, OK. If you wish to continue the use of an inline filter an electric fuel pump will help.
henry (naa114121)
06-16-1999 22:04:19
 Re: Re: Re: Jubilee Help (please:) in reply to ROF, 06-16-1999 18:41:57
I have an NAA with a large (1" diameter) in-line filter and a cutoff valve. Works fine for me.
