Order Ford 8N Parts Online
8N Roll Over Protection System (ROPS) pics
Dave 50 8N
02-09-2000 22:42:58
third party image
Finally got some pics of ROPS at trumpet mounts. Note the plate washer directly above the trumpets, apparently, to keep the base plate level.
Randall(AL)
02-10-2000 14:59:19
 Re: 8N Roll Over Protection System (ROPS) pics in reply to Dave 50 8N, 02-09-2000 22:42:58
Being the "entremanure" I am: I was considering building my own ROPS w/top and I was wondering something? Considering the controversy concerning the weakness of the axle trumpets would the addition of a u-bolt on the inside of the top plate (seatside) that went thru the plate and under the axle housing add some protection against trumpet breakage. This would distribute the force over a larger area of the trumpet thus making a stronger connection. I know the building of your own ROPS is a hotly debated issue but its my own a-- so I'm wanting some input about my u-bolt idea. Stronger or is it gonna be a binding point for certain breakage???? Another thing I'm considering is a 4-point that I know without a doubt is gonna be better than the factory idea.
Jim(Ky)
02-10-2000 07:55:05
Another question, do the 9/16 bolts come with the ROPS? I had to order my replacement bolts from the wharehouse at the air park. Every thing seems to jump from 1/2 to 5/8. I assume they are grade eights.
Dave 50 8N
02-10-2000 08:08:39
 Re: Re: 8N Roll Over Protection System (ROPS) pics in reply to Jim(Ky), 02-10-2000 07:55:05
I'm not sure on the specs on the bolts...bolts came with package deal, instructions and all. The only thing I wish I had done was to drill out the holes on the angle iron on the bottom, so I could hook up 3pt. stablerizer bars on them...or use the old brackets....
Oh, I did have to take the fender skins apart to do this.
