Wouldn't surprise me a bit. I've got a 12-volt and it's the same way, sorta. I have to get up to about 1500 rpm before it'll start charging, but it'll keep charging at anything above the ridiculously low idle I like (frequent "idle wars" with a neighbor's Model T). My starting ritual includes waiting for a few seconds to make sure I've got oil pressure, then revving it up to about 2/3 throttle until the amp guage jumps. If I idle it, it quits charging, but the next time I goose it, it'll start charging. If yours works similarly or you usually run it fast enough to keep charging, I wouldn't worry about it. They can run an awfully long time without charging. Mine seems to replenish what the starter took from the battery in a matter of seconds. If it bugs you enough, you might see if you can get a smaller pulley on your alternator to increase its revs. I've considered this myself, but mainly because I can get a lower idle if I can get an alternator load on the engine way down there.
