3 pt. lifts slowly
Dave 50 8N
02-09-2000 13:41:32
My 3 pt. lift lifts quickly for the first 15" or so, then slowly to the top. Is this normal operation for a lift?
ZANE
02-09-2000 15:30:15
 Re: 3 pt. lifts slowly in reply to Dave 50 8N, 02-09-2000 13:41:32
No it is not normal to change speeds as the lift raises. There is something wrong with the adjustment such as the cam follower pin being worn out or some other adjustment that is allowing the control valve to come back partially after it gets part way up. Needs a good going over.
Possible too that there could be some scoring of the cylinder toward the end of the bore. Need to check for a leak by removing the right hand inspection plate and look for oil coming down from the ram cylinder before you do anything else.
Dave 50 8N
02-09-2000 22:10:01
 Re: Re: 3 pt. lifts slowly in reply to ZANE, 02-09-2000 15:30:15
thanks for the post...I also printed off your detailed post on NAA lifts a few pages back thinking that it might have some application for my N?
