Jubilee transmission oil weight and type
NAA 37730
06-13-1999 10:48:53
The I&T shop manual notes 6 quarts for the transmission. I need to know the proper weight and type?
The same question for the differential which requires 8 quarts of what weight and type? Is there any type of additive required for the differential.
From this board I have seen notes about specific hydraulic oil for the 8N, does the Jubilee use the same type, the shop manual indicates the use of 8 quarts.
Thanks for the help.
AL@NC
06-13-1999 13:41:39
 Re: Jubilee transmission oil weight and type in reply to NAA 37730, 06-13-1999 10:48:53
I use 90wt. in the transmission and differential.
134 in the hydraulics. NAA05075.
Jess
06-13-1999 13:27:44
I changed my rearend oil,trany,and hydraulics with (Ford 134 Hydraulic oil). last summer. everything works just fine.
trans oil.----- -5qt.
rearend oil----- 8.5 qts
Hydraulic oil--- 8 qts.
I hope this is what you was looking for.
Jess NAA-01149
