9N with cracked block
replacement recommendations?
Will
06-11-1999 12:51:13
My 9N has developed a crack at the back of the block that the machine shop can't stitch, JB weld isn't holding and I've decided another block is in order. Any comments on the used or new block assemblies available from CT? $1700 for new, $1200 used rebuilt with exchange. Any other vendors out there offering complerte block assemblies? I hate spending that sort of money, but I'm concerned a block from a boneyard might have nonvisible or undetectable expensive problems. Any comments or input appreciated.
Thanks,
Will
Dave Norcal
06-12-1999 07:26:29
 Re: 9N with cracked block - replacement recommendations? in reply to Will, 06-11-1999 12:51:13
Just recently had a long time mechanic telling me about a cracked block that had been sealed by putting 2 egg whites in the radiator, then running engine til hot... said when they took engine apart several years later, he could see the white in the crack...might be worth a shot as a last ditch effort.... good luck...
Jay Andrews TX
06-11-1999 22:51:37
Will, you didn't tell the proceedure the mach. shop used to repair the leak, and I am assuming it's a water leak to the outside. I have a 8N with a block repair to the left side. A good welder can use a nickle rod and weld cast iron fairly succesful. After adding a short weld it should be peened to keep it from cracking behind the weld. I personally have better luck with brass. If the leak is not too bad, use a stop leak, there are a number of them on the market, and they work fairly well.....Jay
Leon McEntire
07-29-2001 22:24:29
 Re: Re: 9N with cracked block - replacement recommendations? in reply to Jay Andrews TX, 06-11-1999 22:51:37
I have an 8N that has a crack near the front of the block that is allowing oil to pass into the coolant. This is what i've been told by machine shop.
Am I being put on here? Why would a crack develop in a oil passage where there is minimal pessures? Could this really be something else besides a crack in the block?? HEEELLLPPPP!!!
Mac
John.UT
06-11-1999 16:17:01
Before buying a new block ... Did you apply a high temperature sealant to the crack prior to using JB Weld? I didn't the first time, and it leaked within days. The second time I used high temp permadex (sp) prior to the epoxy and it's held for a year and a half (still no leaks). The Crack was over an inch long. Just a thought.
John.UT
P.S. CT sells blocks if you need one
