Order Ford 8N Parts Online
Operation 8N: Brake Plate Fabrication
Ed S. (IL)
05-01-2008 20:33:46
Today, I received the "pre-loved" brake backing plate I bought off eBay, and upon close inspection, saw that the felt seal channel was rusted away pretty badly over about 1/4 the circumference. Since the plate is a fabrication made from a stamped piece with another flat piece spot welded to it to form the channel, I decided to do a little fabrication work. My old backing plate was not damaged around the channel, so I cut a section off it, cut the bad section out of the "new" one, and welded the good piece in (it looks jagged along the inside because I had to cut around the spot welds):
third party image
Total cost was $16, including shipping. Considering new ones are going for $75 with shipping, I was happy to break out the welder. Also painted the clutch pedal, and once everything is dry, should be ready to slip the left axle back in and hook up the brake and clutch pedals.
es
