Order Ford 9N Parts Online
9N DISTRIBUTOR
JESSE
06-09-1999 23:09:28
LOOKING FOR THE OD\ID OF THE FRONT AND REAR BUSHINGS IN THE DISTRIBUTOR. MINE ARE WORN OUT AND THE LOCAL NH DEALER DOES NOT STOCK THE FRONT AND SAYS YOU CAN ONLY GET THE FRONT PLATE WITH BUSHING AND THE REAR HE SAID IS NOT MANUFACTURED BY FORD. I WAS THINKING OF HAVING A MACHINIST FRIEND MAKE ME A COUPLE BUT I LEFT THE ORIGINALS AT HOME AND WE'RE AT WORK. ANYBODY OUT THERE AWAKE THIS TIME OF THE MORNING????? ?
Elvy
06-15-1999 16:43:37
 Re: 9N DISTRIBUTOR in reply to JESSE, 06-09-1999 23:09:28
I'm sittin' here lookin at both new bushings purchased from my friendly local Ford dealer, (Berchtold Equipment Bingo optional URL below.) out of the Tisco catalog, page F-3-12, on 1 May 99.
Front 9N12120 $1.13
Rear 18-12132 $2.20
Tisco also has other distributor repair parts not stocked by FNH.
Toodle & Ooo
Elvy
JimB TX
06-10-1999 10:52:31
I had the same problem with my 8N distributer but I went to my local bearing supply house for the bushings. If you bring in the housing and shaft (with the bushings removed) they can almost always match up a standard bushing.
I learned a long time ago that virtually all bearings are "standard" and a bearing supplier can usually make a match, regardless of what the bearing came out of.
JK MN
06-10-1999 07:09:01
Jesse, You may want to check with the host of this board, or one of the sponsors. Both bushings are available. (9N12120 Front, 18-1232 Rear)
