Order Ford 9N Parts Online
9N 12 volt diagram
Jim Pearson
04-15-2008 00:49:41
Bought a 9n last year. Previous owner converted it to 12v, but did a lot of splicing and short cuts. Does anyone have a proper wiring diagram? Basically I need to know from key to coil to starter and everything in between. Thanks
Sean (TX)
04-15-2008 02:56:45
 Re: 9N 12 volt diagram in reply to ZANE, 04-15-2008 00:49:41
third party image
third party image
Cliff Sadgrove
05-16-2008 06:49:14
 Re: 9N 12 volt diagram in reply to Sean (TX), 04-15-2008 02:56:45
I'm confused. The diagram for the wiring on the 6 to 12 volt conversion shows two pink lines coming from the alternator and going up to the balast resistor. One on the right, one on the left, however, there is only one wire coming out of the alternator and it seems to be going to top left pole of the balast resistor. My alternator just has the one red wire from the pole on the alternator and does not have the white fuse at the top of the alternator.
Can anyone clarify this for me?
Jimmy P. Strahan
04-22-2008 21:10:17
I forgot to say, I have a key activated starter switch. This refers to my request for an 8N 12V alternator wiring diagram> Thanks, Jim
Jimmy P. Strahan
04-22-2008 18:48:19
Can you e-mail me the 12V diagram for the 8N or is it like the 9N or 2N? Thanks, Jim
Jim Pearson
04-16-2008 03:53:03
thanks, this should help
