Order Ford 8N Parts Online
8N Clutch not Releasing
Danti - CO
06-07-1999 21:08:48
Folks,
When I first start my 48 8N I the trans grinds no matter what gear I attempt to put her in. I have to set the throttle to idle and ease her into 2nd. It jumps ahead and finally the clutch releases. Also when working after it has warmed up the clutch is very slow to release. Any suggestions what could be going on?
Thanks to everyone on the board getting my 8N going.
Mike S
06-08-1999 04:30:03
 Re: 8N Clutch not Releasing in reply to Danti - CO, 06-07-1999 21:08:48
It could be something as simple as an adjustment, but more likely, you have an oil leak from the back engine seal and oil is getting onto the pressure plate and clutch plate and making them stick together. When you finally get it going, the oil heats up and spins off, somewhat, thus letting it work. You might try tying the clutch pedal down when you park it and see if that helps.
