Backhoes and 2Ns--Do they mix?
Mike, CT
06-07-1999 09:50:44
Has anybody had any luck with the 3 pt backhoes? Which is a good make and size? All i need one for is the occasional tree stump and small trenching. I have a 2n...thanks all...mike.
chrismWA
06-10-1999 12:41:39
 Re: Backhoes and 2Ns--Do they mix? in reply to Mike, CT, 06-07-1999 09:50:44
The backhoe on my 9N works quite well, contrary to the conventional wisdom about a backhoe on an N. However, it was made specifically for an N--it mounts via a subframe connected to the axle. Its hydraulics are powered by a PTO-driven pump. The unit is ancient however and takes a fair amount of fabrication and engineering skill to fix some of its problems, as parts are no longer available for it.
I wouldn't recommend buying a new backhoe for an N. You can purchase a full-size backhoe/frontloader (e.g. Case 580) at auction for what you'll pay for a new, small backhoe attachment. Unless you get lucky and find a unit like mine, I'd stick to renting a hoe when you need one.
not really........Dell (WA)
06-07-1999 10:22:45
Mike..... ..you might try "www.cadplans.com", they advertize on the N-Board. They have several backhoe plans that could work for you, or at least give you some ideas.
Basically, all N-Tractors, have a hydraulic "weakness" in that backhoes were invented after the N-Tractor was, and the tractor hydraulics just won't do the job.
Some times, it is more cost efficent to hire a backhoe and operator to come in and do it right the first time. N-Tractors are really neat and handy tools, but sometimes you need a different tool to do a job.
Hope this helps..... .Dell
