Order Ford 8N Parts Online
51 8N Ford Backfires
George
06-06-1999 19:07:41
Put a new intake manifold on tractor. Has new carb also. will no longer idle and backfires on hi speed? Also is there a plastic disc in distributor between the points and rotor if so where can I get one? Would the lack of plastic disc cause it to misfire?
Jscott
06-07-1999 06:00:39
 Re: 51 8N Ford Backfires in reply to George, 06-06-1999 19:07:41
Was it backfiring before the work, you did make sure all the ports were clean and there wasn't any material left that would keep the intake manifold from seating? Sounds like you have an air leak somewhere. Use WD 40 or carb cleaner and spray around the manifold and carb and see if the engine speeds up, if it does,here's your leak. Course there is always that nether world of electrics____
Yes, there is a plastic cover there, no I don't believe this is your problem
Other thoughts anyone?
