I've not tried all this on the 9N, but it's general troubleshooting. BE CAREFUL WHEN TRYING ANY OF THE FOLLOWING. Consider: 1. inside the starter--brushes 2. inside the starter switch--physical contacts 3. any cable connection along the line 4. key switch* 5. battery connections 6. battery 1. BE CAREFUL: but you can check for brushes that are too short by having someone hold the starter button down and "lovingly" thumping the starter with a piece of 2x4 or something that will thump but not ruin. WATCH: the starter may begin turning at any moment. Many times, when the starter brushes get too short, a thump will allow the spring to push them little further and contact the armature. (disclaimer: I THINK this starter has brushes, doesn't it?) 2. The starter switch carries a lot of current, especially if it's a 6-volt system. To check this, you can jump around it BEING CAREFUL to use large enough wire to carry the current. Wire too small may instantly become RED HOT! Try to use cable at least as large as the cable to the starter. The switch on the 9N is under the battery. 3. The connection to the starter, coming from, or going to the terminal on the starter might have a corroded or loose connection. A star washer is a good thing to add to these connections. The sharp points of the star washer will actually dig into the metal and make good contact. 4. On the 9N, the key switch does not carry starter current. You can turn the engine over with the key off, but the ignition system won't be energized. With a bad key switch, the 9N won't start, but it will turn over. 5. Battery connections: cable connections to the terminals. They must be clean and bright-shiney (as well as the cables where they contact the terminals) to make sure they make good connection. 6. There are also connections inside the battery that can go bad, which you can't do anything about. Also a dead cell can look good one moment and when you put a load on the battery, drop like a rock! Hope this helps. --Jack B.
