2N Hydraulic Leaks Down
lb
06-05-1999 20:13:11
I am looking at a 2N with a 5' bushhog. It is in excellent shape with new tires and runs good. The only problem is the hydraulic system will not hold the bushhog up when you depress the clutch or turn off the engine. I assume this could be a bad check valve in the hydraulic system. Any thoughts on what it would take to fix this? Should this scare me away from purchase of this tractor?
Ken J
06-06-1999 18:00:27
 Re: 2N Hydraulic Leaks Down in reply to lb, 06-05-1999 20:13:11
If it leaks down when you push in the clutch it is basically turning off the pump. That sounds to me like a bad cylinder or piston or if it is one of the ones with an o-ring piston a bad o-ring. If it is cylinder and piston you are talking between 100 and 200. If it is o-ring you are talking a couple bucks. Sounds like you got a good tool to dicker the price down. The work would take a few hours and a gasket. You have to take off the top cover the cylinder is on the bottom side of that and it is a little heave and awkward.
tifa
08-23-2003 15:51:28
 Re: Re: 2N Hydraulic Leaks Down in reply to Ken J, 06-06-1999 18:00:27
i need this book
