12 VOLT CONVERSION.....COIL?
Mark
06-05-1999 18:14:13
I am thinking of switching my 48 8n with a front mount distributor over to 12 volt. Does anyone know exactly what 12 volt coil I need? The reason I was thinking of changing the coil to 12 volt is I think the 6 volt one that is on it now may be breaking down when it gets hot and the best price I can find on a new one is $60. Thanks for your time!!!!! ! Mark
Mike Wade
07-18-2001 13:44:49
 Re: 12 VOLT CONVERSION.....COIL? in reply to Mark, 06-05-1999 18:14:13
I haave converted my 9N front mount ignition to 12-volt system. I am using a 12 volt coil. The coils keep going bad. Is anyone having this problem and do you have a solution?
Mike
Steve (Ia)
06-06-1999 03:18:20
CT Farm and Country (Central Tractor) catalog number 2121-20 for $25.50. (98 catalog). Phone 1 888 8CT FARM if you're not close to one.
Bob Z
06-05-1999 20:14:03
The part number I usually see (universal?) for the 12-volt front-mount coil is 9N12024-12V.
They're not very solid, though.
If you don't care too much about "correct", email me for instructions to adapt an old coil to accept a "normal" (cylindrical) coil. I've done it to my 2N and it practically starts by pointing your finger in the starter's general vicinity.
J. D.
08-03-2004 06:45:24
 Re: Re: 12 VOLT CONVERSION.....COIL? in reply to Bob Z, 06-05-1999 20:14:03
Bob Z, please e-mail me the instructions to adapt old coil to normal (cylindrical) coil.
Thanks
Mac
TREY
12-20-2002 18:47:15
Could you please tell me how to convert the square 6v coil to work with a modern cylindrical 12v coil? Is there a need for an 12v ignition (ceramic) resistor? thanks,Trey
jerry
04-01-2001 22:05:55
bob Z please e-mail instructions to convert 2-n ford coil from 6 to 12 volts? thank you
Phil (NJ)
06-06-1999 14:45:40
BOb, The original owner of my 9N had modified the
coil to a Standard but I am not happy with the
mounting Point (under the gas tank, above starter). I am changing back to original but will keep the modified assembly (drilled old Coil) for
a backup. Where do you mount the Coil in your modification ?
Thanks
harry
06-08-1999 22:33:05
 Re: Re: Re: 12 VOLT CONVERSION.....COIL? in reply to Phil (NJ), 06-06-1999 14:45:40
the correct part # 12volt coil is 2130-020 at$30.99 not part #2121-020 which is a 6volt coil from ct farm&country phone # 1-888-828-3272
Bob Z
06-07-1999 09:39:55
I've got an alternator on mine, so I mounted the coil upside down on the back of the alternator where I can get to it easily. The one I used (from a 76 BMW 530i) already had one of those mounting straps that only takes one bolt to clamp it on to something.
Though it's nice to keep as much water away from it as you can, it's not vital. My upside down mounting was prompted more by a desire to protect my clumsy self from a nasty jolt than a desire to keep it out of the rain.
bernie
06-07-1999 08:23:33
I am changing over to a regular round coil, I pull the old coil apart and will make external connections so future coil changes will be easy Iamalso going to put in resistor and by pass it so that I can start on 12volts.
